06-14-2007 04:33 PM
06-14-2007 04:47 PM
06-14-2007 05:36 PM
06-14-2007 05:54 PM
06-14-2007 06:03 PM
06-14-2007 07:54 PM
06-15-2007 09:04 AM
endmile said:
Writing to the local variable will set the value at that time, but it's still updating the value of the local variable all the time.
That's not a valid conclusion. There is no "simplest" answer. It's all context-based. There's nothing "bad" or "evil" about local variables. In fact, they tend to be faster than writing to the "Value" property node. Let's just say that proper use depends on understanding how each operates, and once you know that, each can be used effectively.
endmile said:
But in this case, I think the simplest answer is the property node.
06-15-2007 09:18 AM
