08-07-2012 10:26 AM
I have written a VI creating a scripted VI that contains a while loop. So far so good. The problem is that I want to wire a boolean control to the conditional terminal of that while loop. I thought I could do that by either using a property node or an invoke node, but I could not find a way to access the terminal.
Does anyone know how to access the conditional terminal using a node or have another idea to solve the problem?
Steffen.
Solved! Go to Solution.
08-07-2012 10:36 AM
I am not sure why you need property node or invoke node. you can right click at conditional termonal and create control. Refer this.
08-07-2012 10:51 AM
08-07-2012 11:20 AM
@ odessy27:
Because the VI in question is being created using VI scripting and the wiring is supposed to be created the same way... And since I have not found a way to wire two non-existent objects YET, using nodes seems like a logic way to try it...
08-07-2012 11:28 AM
This is what I have so far, but it does not work that way. The VI produces error 1062.
08-08-2012 01:25 AM
Hi no87,
as attachment you will find a complete example.
Hope that help.
Best regards
Dippi
08-08-2012 06:27 AM
Thanks, that solved my problem!
