Windows XP System crash with LabView 7.0
I did the xp sp2 upgrade at home without any issues, but I made them send me a cd.
Message 11 of 16
(1,133 Views)
Good move...
I may have found out what happened...
Apparently, you need to be up-to-date with all the patches & so on BEFORE doing the upgrade to SP2.
I kept that PC off the network and away from any bad patch...
So it was not up-to-date...
Apparently once it is at SP2, it works well...
So I will give it another chance... from scratch (unfortunately)
Message 12 of 16
(1,122 Views)
FWIW, I had a client with a similar case of unexplained lockups, while running tests with my software. It didn't happen on my machine (Win2k) but did on his (WinXP).
We looked in the SYSTEM EVENT LOG, and found a message that preceded EVERY lockup:
3/3/2005 8:29:13 AM Service Control Manager Information None 7036 N/A XXXXXXX The IMAPI CD-Burning COM Service service entered the stopped state.
When we turned OFF this service, he was able to run 15+ tests (20 minutes each) without failure. When we turned it back ON, we got the bad behavior (lockups, "out of virtual memory" messages) back.
Bottom line: The event log can give you clues.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 13 of 16
(1,115 Views)
Were you burning a CD at the time???
(I think not...)
I don't see the link...
Is it a background process... simply waiting, idle, but yet causing a crash..
- confuse-scious -
Message 14 of 16
(1,094 Views)
No, he wasn't burning a CD - there's not even a burner on the machine.
I'm not sure there is a link, I'm just pointing out that the event logs led to the discovery.
Steve Bird
Culverson.com
LinkedIn
Message 15 of 16
(1,090 Views)
strange...
However, in my quest to install XP-SP2... I gave up!!
It doesn't like me or my PC.. (waste of $$)
So it's back to good 'ol Win-2000... for ethernity..
Long live 2K..
No x-mas gifts for Uncle Gates.. 😛
Message 16 of 16
(1,074 Views)
