Windows 7 Enterprise incorrectly recognised as earlier than Windows XP SP3 during Installation
Hi all,
There's an option in the Installer Advanced properties for System Requirements related to OS.
I have a problem where customer installing onto Windows 7 Enterprise PC is being given the message that OS must be Windows XP or later as per the installer setting.
Is this a known issue??  Work-around??
Thanks.
(2,943 Views)
Which LabVIEW version is this?
Rolf Kalbermatter
My Blog
(2,920 Views)
Oh yes.  Good question.
It's built using LV 2015.
(2,915 Views)
Hi battler.
Here's the compatibility charts.
http://digital.ni.com/public.nsf/allkb/B972242574D4BB99862575A7007520CB
LabVIEW 2015 RTE is full compatible with WINDOWS 7. In the installer, your can specify with wich version of OS you want it to be compatible.
Did you check this?
Regars.
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(2,904 Views)
The compatability documentation does not mention Windows 7 ENTERPRISE edition.
(2,857 Views)
