10-19-2012 03:59 AM
i am using Windows 7 64 bit and just installed TS/LV2012 and NI-Visa 5.2
Then i started MAX and want to add a new TCPIP-instrument but it says: "Either NI-VISA is not installed on this system or NI-VISA does not support creating new resources on this type of system".
So i ask me: Is Ni Visa 5.2 not compatible to Windows 7 64 bit? Because on the Website there is only "WIndows Vista" in the product description.
Thx for help
Additional Info: TS/LV is installed on a WIndow7 which is running in a VirtualBox-Image. Can this be also a problem?
Solved! Go to Solution.
10-22-2012 02:47 AM
Hello OnlyOne,
the NI-VISA is compatible with Windows 7 x64.
You can get the Driver from here: NI-VISA 5.2
There's also Windows 7 64-bit listed under compatible operating systems.
That setup should work in a virtual machine like VirtualBox. You have to ensure that the Virtual machine allows to access the network adapter to forward PORTS/IP.
I would recommend you to reinstall the driver mentioned above to ensure that you got the right Version. After that you should check your VirtualBox configuration.
Lam
10-22-2012 03:09 AM
Its working now.
After i run all Windows-Updates in the VirtualBox the VISA was also working in Max.
