Windows 10 and cRIO-9104 compatibility
Hi everybody,
I will change my operative system from Windows 7 to Windows 10 and I work with LabVIEW 2017 (32-bits) and a cRIO-9104 with the specifications shown in the photograph. Is there any compatibility issues that I have to consider before this OS change?
Thanks for the help.
(2,278 Views)
Hi Damian,
your NI9104 is compatible with LV2017 (and up), but it needs the XILINX ISE compiler for its FPGA.
This ISE compiler is NOT compatible with Win10, but you may use the CloudCompile service by NI instead.
(Make sure your company IT department does not block access to this service due to heavy proxy/firewall usage…)
(2,240 Views)
Hi GerdW,
Thanks for the answer. According with Xilinx the ISE compiler 14.7 works with Windows 10, is it possible to work with this compiler and my NI9104 or is it better if I use the CloudCompile?
Best regards.
(2,211 Views)
Hi Damian,
AFAIK NI setup refuses to install XILINX ISE on Win10, so you will need to use the CompileCloud service.
Atleast I do use it for some old cRIO907x targets…
(2,206 Views)
