Windowed FFT for 2D images
   I 'm trying to batch-process a sequence of 2D RGB images, more specifically what I'm doing is selecting a subset (ROI) of each image and calculating, displaying and saving the 2D FFT of the ROI.
My question is: how can I apply a window function to the image prior to performing the FFT?
As far as I am aware, a range of window functions are available for 1D data, but I haven't seen a similar facility for 2D images (I'm using the LabVIEW Vision and Image Processing utilities)...how do I get around this problem?
Thank you very much in advance!
                                 Cheers,
                                         Elisa
(3,087 Views)
Ciao Elisa,
la cosa più facile credo di usare la finestratura 1D e poi unire le varie parti per creare una finestratura 2D.
Valerio
(2,967 Views)
