04-13-2021 03:23 PM
I have had it with NIPM this has to be like machine 10 out of 10 that NIPM has failed and given that B.S. "check you internet connection" message
04-13-2021 03:29 PM - edited 04-13-2021 03:31 PM
I believe this issue has been brought up to NI, and the cause was having a version of VIPM installed that is newer than the one trying to be installed. NI made comments saying they were going to fix it and I think they gave a bug number.
EDIT: Okay NI didn't give a bug number but did say the issue was reproducible, but I did find where I mentioned this issue publicly too.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
04-13-2021 03:53 PM
Now it says something different but still fails.
04-13-2021 07:53 PM
I've not had a big problem but then I'm ok with 40Gb offline installers and isolated single-version installations.
04-14-2021 08:37 AM
The thread I linked to where I originally mentioned this problem, was specifically with an offline install. The "Check your internet connection" error is a catch all when an installer fails even if they installer is an offline one, and has the correct md5.
04-14-2021 02:01 PM
Interesting. As I mentioned, I only have isolated single install environments, so every install (bar the occasional f patch) is on a fresh virtualized OS. Production machines are also basically never upgraded once validated. So I certainly don't have the typical use case. It's a pity the upgrade process is not as smooth as it could be .
04-14-2021 02:36 PM
Honestly the issues with installing have only been around as long as NIPM.
In the past I have had LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, and 2019 all installed on the same computer and never had an issue.
Today it can literally be impossible to install LabVIEW 2020 alone on one computer.
