I am trying to build a complex RT VI. The build is failing because changes are automatically made to the VI every time it is opened to make it run, so the version on the disk is not executable.
Every time I open the VI the * is in the top bar indicating that there are changes to save. I save the changes, close the VI, then open it and the * is there again. When I click "explain changes" it says "SubVI call(s) modified" and the details are: "A subVI's connector pane (or a polymorphic subVI's list of VIs) was modified. Show the Context Help window for the subVI and make sure the connections to the subVI on the block diagram are still correct."
Is there any way to see what subvi call is causing this to happen?
Thanks for your help.
Mike
