Why my force data and displacement data have phase lag
Accepted by topic author Moni98ce
It is a property node under DAQmx Channel see below:
Message 11 of 17
(637 Views)
Hi mcduff,
Thank you very much for your continuous support. I am still facing a problem using the property node. I am attaching a file which is showing the steps you showed is not available in my system. Could you please tell me the reason?
Message 12 of 17
(631 Views)
Try this,
Right Click Property >> Select Filter . Then choose Show All Attributes.
Message 13 of 17
(623 Views)
Hi mcduff,
Thank you very much. Yes, it is working, however, the VI still giving an error message. I am attaching the screenshot regarding the problem.
Message 14 of 17
(619 Views)
Sorry, I am leaving for vacation, don’t have LabVIEW at the moment, but these are errors that you should be able to solve.
The error states that you have exceeded your input range for one of your modules. The message also tells you the valid ranges for that module. Try changing the input to be within range.
good luck
mcduff
Message 15 of 17
(611 Views)
Hi mcduff,
Thank you very much. Yes, I solved it. Now it is working.
Message 16 of 17
(607 Views)
Did you try this? (Order is important)
Message 17 of 17
(603 Views)
