Why is there no beep. Playback of waves works fine, LabVIEW 8.5
Hello Everyone,
I have a problem in LabVIEW 8.5. I have set up my programm, most things already work fine. Except one thing recently decided to quit on me: the beep.vi.
In my main VI there are wave-files being player which works fine, some data is read .... not interessting. And at a certain cue the beep is supposed to heared. But I don't hear it, except if I set the system error sound to true. In that case I can hear the systems error sound when the cues comes up. But if I set it to, let's say 440 hz and 500ms I can't hear anything.
Has anyone an idea what the problem might be? I am pretty much out of ideas ...
Thank you very much
Bye
Jonas
(2,717 Views)
I assumed the Beep used the system speaker, which most new computers dont have. Many have a small buzzer, else the sound card is used for playbacks. That'd be an explanation, but it's only an assumption/theory.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,709 Views)
But the system alart sound, which I can hear is being generated through my speaker. Or do you thing that the system alarm sound come from the speaker while the manually configures sound comes from the systemspeaker?
(2,705 Views)
If it is a buzzer of sorts the frequency range is quite slim. Do you get a "real" sound, a "ding" or a "Brrr"?
(still in theory mode)
/Y
Qestit Systems
(2,699 Views)
@jonidas wrote:
Hello Everyone,
Thank you very much
Bye
Jonas
From what I can gather from the help file, all parameters are ignored.  This leads me to believe that it USED to make a buzz on the internal speaker, but now it plays the default "ding."  Did you happen to change themes or something that maybe made your default system sounds get overwritten?
[Edit] I did a quick search on "beep.vi" and it tells me that you'd be better served paying a wave file.  😉
Bill
CLD
(Mid-Level minion.)
(2,685 Views)
