Why is the Value Property Node of a Typedef control not typedef itself?
This is not preventing me from progressing, but I am puzzled by what I am seeing on one of my diagrams (LV 2011).
I have a typedef control which I am reading around my diagram and passing to some subVI. For this purpose I create a read "Value" Property Node and pass the value to the subVI.
The subVI uses the same typedef control as that in my calling VI but nonetheless there is a coersion dot on my calling VI's diagram when I connect the "Value" to the subVI connector. Why?
The closest to this discussion I found was this old one, but it did not end up with a final answer.... It turns out that the typedef control I am talking about is an enum, but that does not matter.
As a matter of fact, if you connect the Value output of a Property Node to a sequence and create a subVI from that sequence, the corresponding control has lost any link with the typedef. In other words, the Value property node of a typedef control is not a typedef. Why?
(2,532 Views)
[...] Why?
Because you haven't posted an idea here.
Well.. maybe you or somebody else has and I missed it, after all there's more than 14k ideas so for just for LabVIEW.. What? Who said that means there's a lot of room for improvement in LabVIEW??
Jokes appart, if there is an idea, please give the link.
Epictetus
Antoine Chalons
(2,511 Views)
It's not an idea, it is a question. If it has some deep metaphysical foundation, I'd be curious to know. If that turns out to be lingering LabVIEW "feature", then it should generate a CAR (or not) from here, not from the Idea Exchange forum.
(2,489 Views)
