04-17-2014 12:44 PM
A couple of times now (you'd think I would learn my lesson...) I've used the Clean Up Diagram option only for it to render my block diagrams completely unreadable. It's happened on two different systems now..
In this latest incident the flat sequence structure and the labels render as normal but the controls and constants are "smeared out" - for example, instead of being the usual small blue boxes the integer constants are rendered as very tall, thin rectangles. The data flow is completely impossible to discern. It's fascinating.
Anyone seen this before and know how to fix it?
04-17-2014 01:11 PM
That is strange! and those WIRES!
I would love to see your options page for block diagram cleanup (Tools>>Options)
04-17-2014 01:14 PM
Do you have a copy of the VI before you hit block diagram cleanup? I am interested in seeing if we can reproduce it to investigate it.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments | Certified LabVIEW Architect
04-17-2014 01:33 PM
The options were at their default settings :-S
04-17-2014 01:34 PM
Unfortunately not
04-17-2014 02:18 PM
I've seen something similar before and I believe this occurs when cleanup results in a block diagram that is larger than the maximum space allowed in the block diagram. The VI you provided appears to go from ~-30000 pixels to ~+28000 pixels in the Y-direction, which is dangerously close to that limit. I'm not aware of any way to recover a VI once it's been saved in this state.
This KnowledgeBase article includes additional information on the maximum allowed size of the front panel and block diagram:
KnowledgeBase 3JEEP1ZH: Maximum Size for Front Panel and Block Diagram
http://digital.ni.com/public.nsf/allkb/62D66358BBF8A87186256FC50077FA17
04-17-2014 02:23 PM
