Why is cFP web server disconnecting?
-LV 8.0.1
-cFP 2020
My application runs fine when I control straight from my main user interface. The moment I take control via web server and press a control the interface freezes (both web and local) and eventually losses communication. Any ideas?? Thanks.
(2,683 Views)
Hi kevmi2ca,
That does seem very strange.  What kind of web browser are you using?  Before you press a control on the web interface, is the program running?  Do you have indicators with the correct data received from the 2020?  If I am understanding correctly, it sounds like you can receive data from the 2020 just fine, but then it all crashes when you try to send it something (click a control).  Is this correct?
Justin M.
(2,669 Views)
Justin,
We found the problem. There was a tab control in the state machine that was causing the problem. thanks.
(2,659 Views)
