09-27-2006 10:37 AM - edited 09-27-2006 10:37 AM
Message Edited by Lycangeek on 09-27-2006 10:37 AM
12-05-2006 01:45 PM
12-05-2006 05:22 PM
12-10-2006 03:46 PM
12-12-2006 11:04 AM
Well, the fact that it's a property should not matter at all - when the refnum flows out of the property node, the next node in the chain has no idea where it comes from...it just knows it's a reference to type xyz. My guess is that it has more to do with the elements of the Adapter class. Looking at the reflector output, it appears that .NET generics are involved, and this could be part of the problem.
Due to a variety of reasons (such as performance on RT), there are code paths through LabVIEW that assume a class name is never longer than 255 characters...In general, this is a fine assumption as no one is likely to name a class something so long. However, .NET generics have incredibly long class names (hidden from the C# programmer through nice little syntax) and they can exceed 255 characters. When this happens, we try to fail gracefully - and that is my guess as to what you are seeing.
I just recently addressed this issue in a bit more detail here...
12-12-2006 11:20 AM
12-12-2006 11:44 AM
If this is true then why did it work in LV8 and it does not work in LV8.20.
Just asking
12-12-2006 02:16 PM
