OK, moving it does not show it right away (I just tried it). If you drag a box around the function you will see the short-circuit wire going from the string input to the format input. This wire needs to be deleted. One way of doing it is to first delete the wire to the string input to the left (makes the short circuit a broken wire) and then remove all broken wires (ctrl B). /Mikael
