06-19-2008 11:59 AM
06-23-2008 01:47 PM - edited 06-23-2008 01:48 PM
Hello Robert,
Thank you for contacting National Instruments. I believe that the reason
that you are forced to wait for all of your VIs to deploy to your RT target is
due to the change that you make. Certain changes within your program will
force all VIs to be deployed to your RT target whereas other changes may only
result in the one VI needing to be deployed. I do not believe that you
are doing anything wrong in this case. It simply matters on the type of
change that you make to the VI. I hope this helps!
06-23-2008 03:43 PM
What changes fall in which category?
Should moving one object (wire, numeric, primitive, etc.) on the block diagram or front panel by one pixel cause all the VIs to redeploy?
Your answer doesn't seem to fit with behavior I'm seeing...
06-26-2008 08:42 AM
