Why do I get "The plug in for the selected item is not installed on your system"?
I'm getting a Fieldpoint plug-in error involved in my project.  I cannot import my Fieldpoint configuration (previous LabVIEW 8.2.1).
Will I need the Fieldpoint 6.0 version?
(3,906 Views)
Hi Oley,
Does the plug in give you a specific error number?  What is the number?  If not, what does the message say?  You said "previous LabVIEW 8.2.1".  Does this mean you have upgraded to LV 8.5?  Where are you trying to input the configuration?  On another PC?  Into the project?
Some more information on the issue would be great.  Thanks!
Reggie Rector ¦ Applications Engineer ¦ National Instruments
(3,895 Views)
Hello!
There is no error number.  Just "The plug-in for the selected item is not installed on your system" message.
And I have upgraded to the 8.5 version from 8.2.1.  Same PC same project.
I think I am in need of the Fieldpoint 6.0 which I can't find at this time.  😉
Thanks for your time!
(3,884 Views)
Hi Oley,
I think you are correct in thinking it is the drivers.  I believe that downloading the current FieldPoint drivers should fix your problem.  Let me know how this goes!
(3,873 Views)
Sorry I haven't gotten back...
Yes, the new drivers (Aug '07) did the trick.
Full install on my machine (expected) as well as target (not expected).
The install on my machine was fine as all my LabVIEW software is here anyway, but the target machine install was a bit cumbersome as I won't be using most of what's on the driver disc on that machine.  No biggie as it works great now!
Thanks!  Smiley Happy
(3,829 Views)
