03-05-2007 06:54 AM
03-06-2007 12:00 AM
I discovered that my problem is generated because I have on the script more than 64 SPI Write commands (as indicated on page 6-3 of the NI-845x Software User Manual).
Now I don't know if I must split my commands into multiple scripts, or if there is a way to erase the contents of a script.
Has someone already be faced with a similar issue?
Thank you
baloss
03-08-2007 02:40 AM
03-12-2007 01:13 AM
Hello Matthieu,
thank you for your suggestion. I tried to write more scripts in sequence. But in fact it didn't work as expected.
My idea was to erase the contents of the script when the limit of 64 instruction was reached, and then fill it again.
Finally I preferred to use the "Basic" function (there is no limitation on the number of Write/Read operations).
Now everything work fine
Best Regards
baloss
