I am configuring the port (Port 3) as all outputs (even though it is not software configurable, I wanted to get a Task ID for it the first time that I use it). I can set the bit OK using a Port Write, but then when I follow that with a Port Read, I get the 10612 error. The manual says you can readback from the port, and the data that I'm getting seems correct, yet I still get that error. Is this normal, or is there a better way to implement this. I'm just getting started on my first project, and these simple things are frustrating.
Thanks.
