07-08-2013 09:34 PM
It seems only read 200 samples and then stop. Shouldn't I get a continuous wave chart after using shift register on a while loop?
Solved! Go to Solution.
07-08-2013 09:54 PM - edited 07-08-2013 10:02 PM
You must remove Start VI out from the loop...
You cannot 'Start' a task which is already running...
You also remove the Start VI completely from your code... If you do not use Start VI, a measurement task starts automatically when the DAQmx Read VI runs.
Find the attached VI.
07-09-2013 12:52 PM
Thank you! It helps a lot!
