01-14-2010 07:38 AM
All,
I am maintaing some old code. I have SVN (Source control.) Last time I had to get into the code there was no problem. Nothing has changed in the code base. I went to make a few small changes, when I attempted to open the code I get the Fatal Error mentioned in the Subject. What is the cause? And how do I get around it?
I am running LabView 5.1 and 2009 on an XP platform.
Rich
01-14-2010 08:48 AM
01-14-2010 08:52 AM
I have Test Executive the predecessor to Test Stand.
01-15-2010 02:06 AM
rwelch wrote:All,
Rich
FResDir is an exported C API in LabVIEW since version 8.0. Somehow somewhere you installed a LabVIEW component or extension (DLL form) that gets loaded by something in LabVIEW and tries to access that API.
What NI software did you install between the time it worked and when you got this error message?
01-15-2010 11:44 AM
01-15-2010 01:12 PM
Most likely you have an unfortunate interaction between your LabVIEW 5.1 installation and the LabVIEW 8.x or 2009 installation that you use the Mathscript RT installation.
There could be a good chance that you can't run LabVIEW 5.1 (and anything before 8.0) anymore on machines where LabVIEW 2009 and maybe Mathscript RT has been installed.
01-15-2010 01:15 PM
That is what I was afraid of. 😞 Thanks for your help!
~Rich
02-02-2010 10:17 AM
I just got the same message you got. I created a dll with Labview 2009 and wanted to use it in LabView 7.1. As soon as I load the DLL the message pops up! The idea of this dll is that anyone could use it, even if they have an older version of LabView. If anyone has a solution please tell me!!
02-02-2010 10:19 AM
Sorry, no I! I gave up. I am now developing on two seperate machines. Good luck!
Rich
02-02-2010 10:22 AM
fautsch wrote:Hi,
Do you have the LabVIEW 2009 runtime installed on the pc with 7.1?
