06-03-2016 03:42 PM
Hi
I recently downloaded labview with the purpose of writing a script that would take in voltage measurements of a battery using the NI-USB 6008. My code had been running just fine until I extended my labview trial for the 45 day period. I keep receiving Error -229771 referencing my DAQ assistant. Is there any way for me to fix this??
Solved! Go to Solution.
06-04-2016 04:31 AM
Did you search the forum for the error code? There are a few posts showing solutions.
For some reason you have to leave the minus sign off for the the search to work.
This might be a good place to start:
Why Do I Receive Error -229771 at DAQmx Start Task.vi?
steve
