03-28-2022 08:39 PM
If you want to measure the sensitivity of the Reference Mic, the method is the same just change the task Type to AI-Voltage and insert the external amplifier, everything else can remain the same.
Now, the measurement you get is in Vrms, if your test stimulus is 94dB SPL 1kHz tone, then the Vrms directly translates to V/Pascal
03-29-2022 08:08 AM
Thanks,set up task type "AI_Voltage" measured Microphone sensitivity.
