Aliance Member wrote:
> I am creating server which comm over TCP IP ,in this server.vi I
> written TCP Listen func. outside a while loop and TCP Wait on Listen
> func.inside loop .time delay in loop is 1sec. Recived data saving part
> is also inside while loop.
> If single Client application connects to this Server ,after some time
> this(server.vi) crash with giving an error as follows.
> "The instruction at "0x00000000" referenced memory at
> "0x00000000".The memory could not "read".
> click "ok" to terminate
> click "cancel to" debug application.
> * I am sending 3kb size of image file from client to server at 1
> fr/sec.
> Oper sys: - Win NT service pack 5 and 6.
> Labview 5.1.1 and 6i also
> All sugesstions are wellcome.
> Bye
> Vijay K.Raichurka
r
I think that you should use Create Listener and wait on listener in a
separate vi's (server/client), because these two are complementary pair.
Of course you can use these two in a separate loops and with different
connection references.
Sergey Krasnishov
____________________________________
Automated Control Systems
National Instruments Alliance Member
Moscow, Russia
sergey_acs@levsha.ru
http://acs.levsha.ru
