03-03-2008 02:50 PM
03-04-2008 02:04 PM
03-11-2008 12:15 PM
"pid control-multi channel.vi" and "Ready-to-Run Temperature Controller" from NI website.But the input here is A/O voltage for the first example. The second one I am yet to look. However according to my understanding I still have to play with VIs.
03-12-2008
06:45 PM
- last edited on
11-02-2026
08:41 AM
by
Content Cleaner
Hi HopeS,
Unfortunately, PID control theory is not a simple subject, and there is no single answer on parameters, because every system differs in their response to inputs. That's why the P, I, and D parameters are adjustable. We do have a PID autotuning VI found in the same palette which will launch the AutoTuning wizard to help you get mor precise parameters once you have reasonable values to work with already. But again, you need to know a reasonable set of values to operate with for P, I, and D. Once you use the Autotuning Wizard to get new PID values, I would recommend replacing the VI with the normal PID VI and manually entering in the values you found through autotuning. Then you can use an array of all your temperatures (process variables) as the input to the VI. The "simulated" case of the Ready-to-Run Temperature Controller example you found is about as simple as it can get.
And the output of the VI is just going to be based on the mathematical transformations going on within the VI. Since you want a analog output current, you'd rescale that output if necessary and wire it into a DAQ Assistant VI (or DAQmx Write). I'm not sure I understand what you mean with not having to "play with the VIs" - this application will require some small amount of modification to fit your hardware.
