Which of all the subVIs is on top?
My main VI opens the panel of several subVIs during its run. In a specific moment, how can I know which subVI is the top window/panel?
Yifat.
(2,282 Views)
Call Chain Function
from the Help:
Returns the chain of callers from the current VI to the top-level VI. Element 0 of the call chain array contains the name of the lowest VI in the call chain. Subsequent elements are callers of the lower VIs in the call chain. The last element of the call chain array is the name of the top-level VI.
If you are using the current VI as a subVI, you can use this function to identify all the VIs that call the subVI.
Richard
(2,270 Views)
Each VI has a boolean property called "Is Frontmost". I haven't used it myself, but I believe this is what you want.
___________________
Try to take over the world!
(2,259 Views)
