04-04-2014 07:15 AM - edited 04-04-2014 07:16 AM
Hi all,
Im not at all experienced in the use of XML parser library.
How can I extract the value of any TAG?
I use the Get All matched node (See attachment). Get XML gives me:
<title> AAAA </ title>
How can I extract directly the value of the tag (AAAA), without XML tags?
Thanks to all
Solved! Go to Solution.
04-04-2014 08:30 AM
Sorry. I forgot the attachment:
04-04-2014 08:38 AM
You could use the Get Node Text Content.vi from the same palette as the other XML function you are using.
Of with a property node use the "Node value".
04-04-2014 08:52 AM
