Which front panel style is used in Core 2?
Hi!
I'm using LabVIEW 2020 SP1. I'm doing the Core 2 course, and I really like the look of the indicators I've drawn the red circle around. They are generated from a VI supplied by NI. But which style is this? I've created 5 indicators on the right side, in the styles available to me, as far as I can tell, and none of them look the same. The closest is NXG, but it lacks the black frame. How can I find the style of an indicator? I'm trying the right-click menu options, but I cannot figure it out.
Edit: I've uploaded the VI's in a zip.
Message 1 of 8
(474 Views)
I don't know if that's what they used, but the classic palette also has a simple numeric, which has one line of pixels on the boundary. Note that if you change the colors, you can press space in the color selector to toggle between FP/BG/both (see the line of text at the bottom of the selector).
___________________
Try to take over the world!
Message 2 of 8
(428 Views)
You can get this appearance at least by customizing a Classic simple numeric indicator or a NXG Style numeric indicator.
Message 3 of 8
(394 Views)
Looks like a NXG Simple indicator to me.
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
Message 4 of 8
(387 Views)
Accepted by OlaMelien
I partially agree with the rest. This probably started out as and an NXG numeric indicator but it has been modified more than just making the frame black, as simply making the frame black looks like this.
You know years ago I suggesting NI come out with some sort of "Skinning Engine" for front panels. As I don't know about anyone else but all of the LabVIEW controls and indicators and therefore all my front panels are ugly and look dated.
I am an Engineer not an Artist, I don't have the time or talent to design good looking controls and indicators.
Unfortunately, most readers of this Forum, including some real Experts, have not mastered the skill of being able to read the code that Posters fail to post. If we cannot see "what you did wrong", we are unable to tell you how to fix it. (Bob Schor 28 August 2018)
Message 5 of 8
(377 Views)
@RTSLVU wrote:
You know years ago I suggesting NI come out with some sort of "Skinning Engine" for front panels. .
It was late in the last century where I suggested something similar. A that time the instrument was in a darkroom that sometimes needs to be use under dim red light for the study of Rhodopsin. My idea was to define a special skin where everything is just shades of dark red. In the end we just covered all monitors with special red filters whenever needed. 🙂
(Another problem was the fact that some of the physical gauges had red needles, meaning they became invisible under red light. All we could do is look for the shadow of the needle to read the values during tuning. Ah the good old times. :D)
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 6 of 8
(367 Views)
Thank you for your replies.
The reason I asked was first of all, I like the look of that indicator. It catches the eye without being "noisy", so I wanted to find out if it was a one of those standard themes. Alright, I guess it is not, that's fine. I know I can customize these things.
I also agree the whole system for styles could do with an update.
Thanks for your help, everybody! Kudos all around!
Message 7 of 8
(301 Views)
Like tst, I think those are Clasic-Simple numerics.
Note for the OP: there are custom sets of controls available via VIPM.  My own set which I use is called Flatline Controls, and there is also a good flat set from JKI
Message 8 of 8
(285 Views)
