05-01-2019 08:34 PM
Good Day,
I understand that with Labview it is possible to build your own software to control the pumps, etc.
Does LabVIew offer ready made applicaitons? The plan is to connect the softare to ISCO Pump D series to be able to removetly control and log the data. There are so many on the website. Below is the link with example of Pump Control.VI this is the desired application to have.
Which product should I buy to be able to do these basic requierements?
Regards
Max
05-02-2019 03:21 AM
Teledyne made that program as part of their LabVIEW Toolkit. They should have a download somewhere.
I'd be a bit sceptic about the toolkit. They don't spell LabVIEW the right way, which is a tell for crappy code.
If you want to make a program that does exactly what you want, you can start by doing some courses and then download a ISCO driver. Maybe this one?
Those pumps can be complex, but the communication protocol isn't.
You can also consider outsourcing he project, or let an alliance partner make a start and then hand it over.
05-06-2019 12:47 AM
Many thanks for your response. very helpful. I got very confused with these available apps within LabVIEW. I've heard Pump control.vi works fine, so I thought could just buy this version, instead of reinventing the wheel or spending time in programming. At least now it is all clear.
Max
