Which DAQ Driver I need to use for PCIe 6321 card
I tried to install DAQ 9.2.1mx downloaded from net, but then I was unable to use DAQmx related sub VI's.... Then I tried DAQ 9.0mx but same happened with that also... Please suggest the solution.
Any help from your side will be appreciated... ThanksSmiley Happy
(5,043 Views)
Hi Rupali,
what version of LabVIEW do you use? Which error do you get? Can you see the palette in LabVIEW?
Mike
(5,037 Views)
Hello... I'm using LabVIEW 7.1 and unable to get DAQmx Sub VI's in pallet... Do you think that I need to upgrade my LabVIEW version...?
(5,031 Views)
Hi Rupali,
yes you have to update LabVIEW to get support for this device.
Mike
(5,023 Views)
Accepted by topic author Rupali
LabVIEW 7.1 is too old, 8.5, 8.6, 2009 may be better. At the same you should choose the corresponding DAQ driver.
Colin Zhang
LV7.1/8.2/8.2.1/8.5/8.6/9.0/2010/2011/2013/2015/2016/2020; test system development; FPGA; PCB layout; circuit design...
Please Mark the solution as accepted if your problem is solved and donate kudoes
Home--colinzhang.net: My Blog
iTestGroup: One-step test solution provider!
ONTAP.LTD : PCBA test solution provider!
(5,010 Views)
Hello to all.... Will try today with LabVIEW 2009 and let you know the result.... Thanks for advice.... Smiley Happy
(4,997 Views)
Hello to all.... The problem is solved by upgrading LabVIEW 7.1 to 2009.... Thanks to all.. Smiley Happy
(4,976 Views)
