> The first has to do with a diagram for a vi I
> wrote. It's flat out disappeared.
Hopefully your diagram hasn't really gone walkabout, as it's the code that the VI needs to execute. If you open your VI, and all you see is the front panel, select the "Window" menu, and then "Show Diagram". As the menu item suggests, you can also get to it by pressing ctrl+E.
Hope that helps!
Christopher G. Relf
Christopher.Relf@mBox.com.au
Int'l Voicemail & Fax: +61 2 8080 8132
Aust Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specifically referenced I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) T
his email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
