Where is the "Show connector" menu in LV 7.1 ?
I wanted to change a connector pane of a subVI.
I right-clicked on the VI icon but I can't see the "Show connector" option.
What is the procedure to assign terminals of subVI in LV 7.1
(4,418 Views)
Show connector appears in the same place as in previous versions of Labview. Are you sure you are right clicking the icon on the front panel? Show connector does not appear on the block diagram icon menu.
- tbob
Inventor of the WORM Global
(4,410 Views)
It's there but only when you do it from the front panel. It's not available from the block diagram icon because it's only used to make/modify connections to front panel objects.
(4,408 Views)
I started to early this morning,
I clicked in the diagram...
Thanks for your help
(4,402 Views)
