Where can I get the spliced power outlet to use with power measurement system
I am trying to try to do something with the power measurement like the white paper
"How to Get Started With the Power Monitoring Starter Kit for NI CompactRIO"
http://www.ni.com/white-paper/11336/en/
Could someone tell me where I can get the spliced power outlet so I can measure the current directly without using current sensor/transformer?
(2,912 Views)
The connectors come with the module. There is a part number if you need more. Contact NI for pricing. I'm pretty sure you have to make the actual assembly yourself. Some basic tools and a soldering iron is about all that you need.
(2,890 Views)
(2,829 Views)
