02-07-2007 04:44 PM
02-09-2007 02:17 PM
Hi Kevin,
We don't have that particular example posted. I'm checking to see if we made that example public but your best bet for now is to work off of the included pitcures. The VI's used are pretty straightforward - it's really just switching to ch0, reading, switching to the cjcChannel, reading and then scaling the voltage based on the Thermocouple. Another VI that has very similar functionality (it uses scanning instead of single connections) would be the niSwitch Thermocouple Measurements.vi in example finder.
Cheers,
Andrew S.
02-09-2007 04:52 PM
02-12-2007 07:08 PM
Kevin,
That VI wouldn't apply to the 4351. A better resource for calculating your system accuracy is the NI 435X User Manual. The tables and examples on pages 53-58 are probably where you would want to get started.
Cheers,
Andrew S
02-13-2007 11:37 AM
Andrew:
Yes, I'm familiar with the NI-4351 specification tables and am up to speed with the accuracy calculations. I do agree it's good to start by calculating the accuracy on paper first but then I was hoping to be able to measure the actual "effective resolution" like they do in the tutorial to make sure I've got my system configured correctly and to use as a benchmark to see if the system resolution drifts over time.
I was pretty sure I wouldn't be able to use Resolution Benchmarking.vi as is with the 4351 but mainly wanted to see the statistics used to calculate the Effective Resolution and the Signal Noise Error (statistics aren't my strong suit) and figured the code could be modified to take readings with the 4351 instrument.
Thanks again for any further help you can provide me,
Kevin Hanson
02-14-2007 01:07 PM
