Where can I dowmload NI LabVIEW Instrument Design Libraries for IF Digitizers 18.0 or later?
Dear all,
I try to edit FPGA code for 5624R IF digitizer. My Labview version is 2018. However, I can not find NI LabVIEW Instrument Design Libraries for IF Digitizers 18.0 or later version on NI official website or RF drivers suit. Dose anyone knows where to download it? Otherwise, Are there other driver or toolkit supporting 5624 FPGA editing on LabVIEW 2018?
(2,438 Views)
Hi Raymond,
I've had the same question before hence I contact NI, the IDL for IF Digitizers was deprecated in LabVIEW 2015, so if you want to continue developing with the IDLs you gotta stay on LabVIEW 2015.
Otherwise if you are interested in making FPGA modifications in newer versions of LabVIEW, NI do provide FPGA extensions: http://zone.ni.com/reference/en-XX/help/372058U-01/nirfsa/fpga_extensions/.
According to the document, there seems to be a pre-installed 5624R bitfile in the NI-RFSA driver.
(2,347 Views)
See this thread for the drivers (which you may have already) for versions after 2015:
https://forums.ni.com/t5/LabVIEW/NI-LabVIEW-Instrument-Design-Libraries-for-IF-Digitizers-15-0/m-p/3...
ALE Consultants
(2,329 Views)
