01-15-2007 09:44 AM
01-15-2007 10:21 AM
Epictetus
01-16-2007 06:19 AM
01-17-2007 03:14 AM
HI bbl,
It is normal for you top not have the option of selecting the functions palette when you have the Front Panel as the active window.
This is because you can not put any of the function vi's on the front panel. You will find that if you select the block diagram the same happens in reverse. You can now select the functions palette but not the controlls palette.
AdamB
01-17-2007 05:07 AM
