01-14-2013 12:57 PM
01-15-2013 07:46 PM
Hi Steve
The examples change with every release, so it is probably that one of those examples in that folder do what you want. Or do you have any specific reason for that example?
You can also look for the example in LabVIEW 2011 save it and open it in LabVIEW 2012
Esteban Rivel
01-17-2013 10:18 AM
Esteban,
Thanks for the feedback. From what I've read online this example was supposed to have shipped with every release of VDM since around 2002, and is even referred to in the LV 2011 and 2012 manuals. I am looking for this specific example because I need to do non-linear calibrations and the manuals all point to this LLB.
Steve
01-18-2013 12:17 PM
Steve,
Unfortuantely this appears to be a bug with VDM 2011. Corrective Action Request - #322706 has already been filed for this. The suggested workaround is to uninstall VDM 2011 then reinstall 2010 to copy the example.
01-18-2013 12:18 PM
The bug is also in VDM 2012 so you would need to uninstall VDM 2012 then reinstall VDM 2010.
01-18-2013 12:43 PM
Isaac,
Thank you for the replies. I have LV 8.6, 2010, and 2012 installed and none of them have installed this LLB. Is it possible for you to post this LLB as a reply to this discussion or to email it to me? Or can you please point me towards another example that shows how to correct for both perspective and nonlinear distortion, as described in the NI Vision Concepts Manual?
Thanks again
Steve
01-21-2013 03:41 PM
Attached is the shipped example.
01-21-2013 07:36 PM
Thanks, Isaac. I appreciate it.
Steve
09-12-2014 12:54 AM
Please help me as I am unable to find Nonlinear Calibration Example.llb . I have labview 2012 . Also I have opened zip document that you have attached but it shows missing subvi.
09-12-2014 01:51 PM
Do you also have the Vision Development Module? If not, that is likely where your dependency problems are created.
