Alexei,
This may or may not help, I was tasked to do something similar
recently and found an error in their driver. The GPIB VISA worked
fine, but when I tried it on serial it played up. There was an errant
carriage return (or CR/LF I can't remember). GPIB liked one and Serial
liked the other. It always amuses me that we never have problems with
Quickbasic!.
If you want me to dig deeper give me a shout.
Steve Watts
On Thu, 24 Jan 2002 06:16:55 -0800 (PST), "Alexei V. Soloviev"
wrote:
>When trying to work with Agilent 34401A multimeter (serial RS-232
>connection), HP34401A Getting Started.vi gives always the message:
>"Error 1073807369 occurred at Old VISA Open ".
>Baud rate and parity are set correctly, RS-232 cable is also connecte
d
>correctly. My QuickBasic program has no problems to read and write to
>the Multimeter. It is obviously a software problem: the same error is
>persistent if I disconnect RS-232 cable.
> I downloaded NI-VISA 2.6 for Windows 95/98/NT/ME/2000/XP frorm
> digital.ni.com and installed it. But it did not help.
>Thank you in advance
>Best regards
>Alexei Soloviev
