04-15-2020 12:28 PM
The Help for the LabVIEW IMAQdx Configure Grab node mentions, "Use the IMAQdx Unconfigure Acquisition VI to unconfigure the acquisition." However, I can find no information about when one would need to unconfigure the acquisition. Does a session need to be unconfigured before being re-configured? Is it recommended to unconfigure before Close Camera, or does the Close Camera take care of that cleanup?
04-15-2020 05:34 PM
While I've used Configure Acquisition, I've never used Unconfigure, but just closed the Camera and stopped the program.
However, if (for some reason) I wanted to acquire images with, say, 10 buffers, then after taking some frames wanted to change the number of buffers, I would Unconfigure, then Configure again. If nothing changes, however, just forget about it (say that with a Brooklyn accent).
