06-13-2022 12:53 AM
Actually I want to read a data from csv file and display to user when reading into table indicator unwanted symbols are displaying and same I rounded with black ink.
06-13-2022 01:47 AM
Unwanted characters are embedded in your files, post one of them as an example. Are the symbols always at the beginning of the file?
06-13-2022 07:57 AM
You're thinking it might be Unicode BOM?
06-13-2022 08:05 AM
Yes. Probably UTF-8, otherwise the table display would be considerably funnier.
06-13-2022 09:03 AM
I know that sometimes Windows Notepad will add a BOM if it thinks one is needed. I've seen where I opened up a text file in Notepad and after I closed it, it added the BOM without telling me it did or asking me to save it.
06-13-2022 09:22 AM
TrimWhitespace will probably solve it, but you should check your .csv and/or how you write to it.
06-13-2022 08:54 PM
I don't know if it would be considered "white space"
06-20-2022 09:06 PM
Yes at starting of the row
06-21-2022 08:47 AM - edited 06-21-2022 08:49 AM
Rename your file from csv to txt and open it in a text editor.
For example, notpad.exe offers you to save a file with or without Byte Order Mark.
Try "Save as" and in "Encoding", choose one without BOM. UTF-8 might work. Try ANSI if it does not.
06-21-2022 04:24 PM
We've just started putting this (or similar) on our code that opens text files:
While you can make it so individual files or editors will not leave the mark by changing some program somewhere, guaranteeing that every user always does it is impossible. It's much more practical to just get used to removing/ignoring it than it is to complain about it or try to get all text file users to reconfigure Notepad or whatever they use.
