When deleting cases in a consecutively numbered CASE structure can one shift down the higher case numbers in order to make all the cases again consecutive?
An example: 1) Created a case that had 100 numerical cases all in consecutive order going from "1 .. 100";
                     2) Found that I need to delete 10 consecutive cases from 41 to 50;
                     3) After completing this operation I find that I now have: an 'IF' structure that has cases numbered from:
                         "1 .. 40, 51 .. 100";
                     4) I would like to colapse this from "Item 3" to the following: "1 .. 90"; with all 90 cases in monotonic,
                         consecutive order, with NO holes;
                     5) I know that this can be done, but unfortunently, rather slowly and painfully, using the following process:
                            a) Delete the 10 consecutive cases that one no longer needs,
                            b) Then add a case after case 40, (which is blank of course), then again after the new case 41, and
                                 continue this till you have created case 50; all in consecutive order, (for these 10 new blank cases),
                            c) Now go to case 51 and at the top middle of this case, right click and get a drop down menu that gives
                                you  a number of options; one of them being, (paraphrased): "~Exchange this case block diagram
                                with the case number that you now choose",
                            d) So starting with case 51, exchange it's block diagram with case 41, then exchange case 52 with case
                                42; now continue to iterate until you finally exchange case 60 with the blank case 50,
                            e) Now do 'd' four (4) more times for a total of 50 exchanges, (wow, thats exhausting to even think
                                about),
                      6) Your, now done with this operation that has at least 50 exchanges and a number of other operations. If
                           you have done everything exactly correctly then you now have an 'IF' structure that has 90 cases
                           numbered from 1 to 90 in monotonic consecutive order, (with no holes),
END EXAMPLE
   My assumption is that LabVIEW must have a better and easier approach to doing this above operation. I haven't seen
a better approach after a few minutes scan, so I know that I MUST be missing something. My question is what am I missing
and how can I do the above operation easier and with a lot less time???????
(2,399 Views)
A case structure with 100 cases seems like a programmers nightmare. 😞
So far you are only telling us what case numbers you want, but you're not telling us what is INSIDE these cases. Do all cases have different code?
It seems that the new case 41 need to contain the code of the old case 51 and so on. I would think easiest would be to delete cases 41..50 then simply rename the higher cases. For example, go to case 51 and change the 51 to 41, then 52 to 42, etc. (no need to add blank cases then swap, etc.)
In any "case" (no pun intended), it seems to me that maybe you are approaching that entire code structure the wrong way. Can you tell us a bit more about your program and what is is supposed to do?
I
(2,390 Views)
                                about),
That's an awful amount of effort wasted,  I must say!Smiley Surprised
All you have to do is click  on value '51' in case selector label and change it to '41' Smiley Wink
Repeat fhis for all subsequent cases
Hope this helps,
regards,
Dev
(2,384 Views)
Christian, hope your recuperation is complete
I did not see Christian's post before answering your query
altenbach: In any "case" (no pun intended), it seems to me that maybe you are approaching that entire code structure the wrong way. Can you tell us a bit more about your program and what is is supposed to do?
I would second that
(2,382 Views)
Thank you very much for your concise comments and of course I used your approach this morning ... very simple &
VERY NICE!!! I was making a simple task much harder than it should have been. Hard to believe that I've been doing
this for almost 8 years now. Thanks Again!  - Aerospacer
As to your question in "Reply 4 of 4", here is:
Actually this structure works quite well for my needs, (in which I'm modifying an existing module with this structure
contained within it, ~ 35% modified). I've got 6 clusters each with 8 to 18 objects within them. These objects represent PCB
cards or instruments which can be repeated as necessary. But these objects are actually represented as True/False
switchs. Therefore if an operator toggles a switch, (object), then the PCB card or instrument which has a functional
representation, (sub-VI), is then called and the operator can make changes as needed. I use: 1) cluster to array.nivi for
all six clusters; 2) concatenate arrays.nivi then use the search.nivi with a 'True' to find the operator actuated instrument,
(capability), that that operator wishes to make changes too. NOTE: the final array size is between 40 to 80, I just used
100 because it's easy to work with.
Again, Thanks and Regards,  Aerospacer
(2,347 Views)
