When I read images from TDM reading speed falls down, why?
I'm using TDM storage to save images, every image is saved in its own channel. When I read the images, reading speed slows. And the same probleme is when I save the images. But I need to write (read) images as fast as possible and with the same time period for all the time.
Can you help me?
Thank you Eva
(2,501 Views)
Eva:
I would need more information to further assist you. How many images are you reading/writting ? Is the operation faster if you use fewer images or is it slow all the time?
Rudi N.
(2,488 Views)
Now I have 200 - 300 images, but in future is posible it will be thousands. The main problam is that at the begining it reads (writes) quite quickly, but with every new read image is it slower. The time, which is necessery to read (write) new image is longer, so there isn't constant period between the images. If I use fewer (50) images, the period also increases.
I hope its enough information, so you ca help me now.
Thanks Eva
(2,483 Views)
Hi Eva,
The native TDM Storage VI's are not necessarily the best solution for every application -- in particular, when you need to stream large amounts of data and time is critical. I would suggest instead that you use the TDM Header Writer VI's:
Introduction to the LabVIEW TDM Header Writer VIs
The idea is that you stream your data to disk in a binary format and then add the TDM header (channel) channel information later. We are always looking for ways to improve our storage VI's. If you have any ideas, you are certainly welcome to submit them:
Hope this helps!
Charlie S.
Visit ni.com/gettingstarted for step-by-step help in setting up your system
(2,467 Views)
