When I generate chirp by LabVIEW function, there occurs aliasing at specific sampling rate.
Hello there,
I'm an user of LabVIEW. 🙂
There is a strange thing at chirp function.
When I am going to generate chirp signal from 20 Hz to 20k Hz, I used to set the sampling rate as 44.1k Hz.
However, this time I have to measure the signal by NI9234, I need to set the sampling rate as 51.2k Hz.
In this situation, there occurs a strange happening!
When the sampling rate is 44.1k Hz, there is no aliasing when I am hearing.
However, when I set the sampling rate as 51.2k Hz, there is an aliasing!
I think you could re-generate by your LabVIEW as following code.
Is there any additional knowledge about singal processing?
Thank you for reading!
Message 1 of 1
(2,439 Views)
