What software do I need to run executables files
Hi
I have application where I acquire data from sensors using stain gauge and thermocouple modules with 6225M DAQ card. Also I am writing some data that i get from a joy stick to a serial port in the same application. In order to run executable file of this application what software do I need?  I installed labview runtime engine in the target machine but it didn't run my program. Do I need to install any drivers for the DAQ card?  i am using labview 8.6.
(2,178 Views)
Of course you need to install the DAQmx driver. If you have LabVIEW 8.x, when you create the installer, you have the option to install different versions of the driver ranging from a full install to a minimal one. If you have tasks saved in MAX, you would want to install MAX and export your current config. Then select to have the installer import the config on the pc with the exe.
(2,168 Views)
