01-03-2018 06:16 PM
Dear friends,
My problem can run without error only for 10 sec around, then I got this error. Anyone could advise me what's meaning of the error and how to fix it? Thank you,
Error -1074118627 occurred at niUSRP Write Tx Data (2D CDB).vi
Possible reason(s):
A runtime or configuration error occurred.
Code: 312
Details: EnvironmentError: IOError: 0/Radio_0 user_reg_read64() failed: EnvironmentError: IOError: [0/Radio_0] sr_read64() failed: EnvironmentError: IOError: Block ctrl (CE_01_Port_40) packet parse error - EnvironmentError: IOError: Expected packet index: 17 Received index: 16
01-04-2018 04:11 PM
Hi Sunson29,
What USRP are you using? What software are you using with versions (USRP, LabVIEW, etc)?
I highly recommend that you contact support at ni.com/support.
Cheers,
Michael
01-04-2018 06:34 PM
Hi Michael,
I am using the lastest labview on windows 10, with usrp 2943 and 2954. Thank you. You have any clue?
01-04-2018 07:16 PM
Link the service request.
I'm about to go down the USRP rabbit hole myself. I always appreciate the screams of those who have gone through the process before.
01-05-2018 12:19 PM
Hi sunson,
There is a known issue with certain SBX daughter-boards that results in this error. The 2943 and 2954 do not use those daughterboards, so this will need to be escalated through support channels to determine a resolution. Can you contact support at ni.com/support so they can investigate this further?
For reference, here is another forum post that covers this topic.
Cheers,
Michael
01-05-2018 12:22 PM
Hi Michael,
I think I made a mistake. I am using usrp 2943 and 2953 (not 2954). Does this make any difference? Thank you again.
01-05-2018 12:26 PM
No you should still contact support@ni.com
Cheers
