What's going on with the errors here?
Hi all,
My run arrow is unbroken, but my error list shows four errors (and numerous warnings). I have always thought that errors caused broken run arrows? In my error list, snapshot below (with some confidential info smeared out), I get 4 errors and 68 warnings. If I uncheck the Show Warnings tag, the warnings and errors disappear! (second snapshot below). Anyone know what's up here? If it helps, I've included the strict type-defined cluster that the errors are referring to.
My second confusing issue: I'm not sure I understand how a front panel control based on strict type-defined cluster can have an undefined type? If it's referring to some of the elements within the cluster (which are all refnums) then there's nothing I can do as three of them are string refnums and have the "Include type def" option ghosted out!? (they can be seen as the three controls without red stars in the third snapshot).
Anyone with any pearls of wisdom?
Cheers,
Thoric
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 1 of 8
(3,256 Views)
Does this happen with any VI that uses this control, or with a specific VI? If it happens with any VI, then it's possible the control has become corrupted. I would suggest recreating it from scratch. You can close all VIs that use it, then back up the control, create it new, and then save it under the same filename so that when VIs open they will use the new control.
Message 2 of 8
(3,226 Views)
Thanks for the suggestion, I'll have to try this tomorrow as I have no time left today. Also, I'm using Source Control, so it'll take me a moment to figure out how to do this! Smiley Very Happy
Will post the result in the morning! Smiley Happy
Thoric
Message 3 of 8
(3,215 Views)
Am a glutton for punishment. Tried this from home, replaced the strict type-defined cluster of indicator refnums with a new custom control - identical in design. Reloaded main vi from project and all is well Smiley Happy
Most bizarre bug there though. Have had things get corrupted before, but usually when it's a far bigger custom control, not one so small/simple.
Thanks for the help!
Thoric
Message Edited by Thoric on 06-16-2008 08:04 PM
Message 4 of 8
(3,195 Views)
I want to rate your response, but cannot see an option to rate messages anymore. Has this feature been removed?
Message 5 of 8
(3,189 Views)
You need to have at least 50 messages posted before you are able to rate other people's replies.
Message 6 of 8
(3,174 Views)
Unfortunately, corruption can happen with any sized file. Smiley Sad Glad that recreating it fixed the problem.
Message rating has not been removed. However, you cannot rate until you've had 50 posts. This was a compromise the forum moderators reached due to some abuse/misuse.
Message 7 of 8
(3,172 Views)
I have sometimes seen these sorts of extraneous errors appear when there is another error somewhere in the code. Fix that one and all the others go away too.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 8 of 8
(3,152 Views)
