What library to use to link DSSetHandleSize on LabView 2009 RT
I have a C DLL that uses VISA to return BAR0 registers based upon specific resource names. I want to modify that DLL to pass in a cluster that will be filled in with all resource names from VISA. The cluster is an array of (int, string). To allocate space for the strings within the DLL, I am calling DSSetHandleSize. However, the link is failing because there are no libraries in "C:\Program Files (x86)\National Instruments\Shared\CVI\Extlib\msvc" that contain the definition.  Since I'm using RT, I'm rather constrained; but I thought this would be supported by RT.  I am building on a Windows 7 x64 box and deploying it to a PXI chassis. Any help would be appreciated.
(2,399 Views)
It would be best if you post this question on the Real Time forums since you are working with RT.
(2,364 Views)
Just guessing here - try linking against lvrt.dll. On my machine the RT versions are under National Instruments\RT Images\Labview\[version].
(2,349 Views)
