Here is what I want to do,
I have several PC's that run different types of tests. I want to use a global variable, running on a single PC, that acts like a sever that can be accessed by the other PC's in my lab. This Global variable will store the hostnames of the different PC's that are currently running each test, along with a description of the test. Then, a user can access this Global variable to read the different values and select the PC and connect to it's desktop using Remote Desktop in Windows.
Is it possible to write data to the Global variable that is running on the single PC?
What is the best way to do this? Does anyone have a sample VI?
What is the best way to then read the data from the Global variable?
(I will probably use an array\cluster to store the hostnames.)
