02-27-2006 05:32 PM
02-28-2006 02:43 PM
While either method will work fine, I recommend clearing the task as soon as you are finished with it. The benefit to this is that the resources that the task uses will be freed and you can use them again later in your program. If you don't clear the task when you are finished, then those resources will still be reserved. I hope that you find this information helpful.
Hal L.
03-01-2006 12:09 PM
